Старый 11.12.2010, 00:14   #1
Microsoft Dynamics CRM Team Blog: Integrating Microsoft Dynamics CRM via App Fabric (using SAML token)
Источник: http://blogs.msdn.com/b/crm/archive/...aml-token.aspx
In an earlier article called Integrating Microsoft Dynamics CRM via App Fabric, we saw how we can integrate Microsoft Dynamics CRM 2011 with an external application via the Windows Azure platform App Fabric. We converted a classical pull model of integration to a more efficient push model. The data was queried only when needed.
I would like to draw your attention to the authentication mechanism that was employed to authenticate with the Access Control Service (ACS). We used the management key approach and this implicitly made assumption that the key can be shared between CRM system and the owner of the syncing module. In many of the integration scenarios the CRM system and the external application (including the syncing module) may not be owned by the same business. The sharing of the ACS account’s management key is not possible.
Editor’s Note: For more overview material on AppFabric’s ACS there is an excellent article here: Access Control in the Cloud: Windows Azure AppFabric’s ACS.
Consider the scenario where an ISV has setup an endpoint on the App Fabric to which they want other CRM systems, its customers, to post data so that it can provide appropriate service. The ISV owns the Azure account and the rules on the ACS. It needs to enable its customer’s CRM systems to be able to post data to its endpoint and also be able to easily control and filter who is allowed to do so.
ACS provides the use of SAML tokens to authenticate and this is a good alternative for our need. Our goal is to allow CRM system to authenticate via SAML token and also allow ISV to configure rules in ACS based on the token’s issuer signature.
We start by first procuring an X509 certificate. You can use a self signed certificate too. Generate both private (.pfx) and public (.cer) certificate parts of the certificate. Add the .pfx certificate to the certificate store of the Async box, as we are running the plug-in asynchronously, under Computer account -> Local computer -> Personal -> Certificates.
Update the RetrieveAuthBehavior() show in the earlier blog sample with the code below.
<div style="padding-bottom: 0px; margin: 0px; padding-left: 0px; padding-right: 0px; display: inline; float: none; padding-top: 0px" id="scid:9D7513F9-C04C-4721-824A-2B34F0212519:138f3056-1d5f-4e32-8d41-5f2136d119e0" class="wlWriterSmartContent">private TransportClientEndpointBehavior RetrieveAuthBehavior(){ // Behavior TransportClientEndpointBehavior behavior =new TransportClientEndpointBehavior(); behavior.CredentialType = TransportClientCredentialType.Saml; behavior.Credentials.Saml.SamlToken = GetTokenString(); return behavior;}privatestring GetTokenString(){ // Generate Saml assertions..string issuerName ="localhost"; Saml2NameIdentifier saml2NameIdentifier =new Saml2NameIdentifier(issuerName); // this is the issuer name. Saml2Assertion saml2Assertion =new Saml2Assertion(saml2NameIdentifier); Uri acsScope = ServiceBusEnvironment.CreateAccessControlUri(SolutionName); saml2Assertion.Conditions =new Saml2Conditions(); saml2Assertion.Conditions.AudienceRestrictions.Add( new Saml2AudienceRestriction(acsScope)); // this is the ACS uri. saml2Assertion.Conditions.NotOnOrAfter = DateTime.UtcNow.AddHours(1); saml2Assertion.Conditions.NotBefore = DateTime.UtcNow.AddHours(-1); X509Certificate2 localCert = RetrieveCertificate(StoreLocation.LocalMachine, StoreName.My, X509FindType.FindBySubjectName, issuerName); if (!localCert.HasPrivateKey) { thrownew InvalidPluginExecutionException("Certificate should have private key."); } saml2Assertion.SigningCredentials =new X509SigningCredentials(localCert); // Add organization assertion. saml2Assertion.Statements.Add( new Saml2AttributeStatement( new Saml2Attribute("http://schemas.microsoft.com/crm/2007/Claims", "Org1"))); // The submitter should always be a bearer. saml2Assertion.Subject =new Saml2Subject(new Saml2SubjectConfirmation(Saml2Constants.ConfirmationMethods.Bearer)); // Wrap it into a security token. Saml2SecurityTokenHandler tokenHandler =new Saml2SecurityTokenHandler(); Saml2SecurityToken securityToken =new Saml2SecurityToken(saml2Assertion); // Serialize the security token. StringBuilder sb =new StringBuilder(); using (XmlWriter writer = XmlTextWriter.Create(new StringWriter(sb, CultureInfo.InvariantCulture))) { tokenHandler.WriteToken(writer, securityToken); writer.Close(); } return sb.ToString();}
Microsoft Dynamics CRM Team Blog: Integrating Microsoft Dynamics CRM via App Fabric Blog bot Dynamics CRM: Blogs 0 09.02.2010 00:08
Microsoft Dynamics CRM Team Blog: Top 14 Microsoft Dynamics CRM Sites and Downloads Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 22:59.
