Старый 19.12.2010, 21:23   #12
AX2009
Гость
n/a
Сообщение от someOne Посмотреть сообщение
а версия glp слоя какая ? (можно посмотреть в файле axglp.version)
должна быть 5.0.1500.3761
Так и есть
вот лог
\Classes\BookDataCalc_Purch_RU\dialog 1 3 delete from GLS
\Classes\BookDataCalc_Purch_RU\getFromDialog 1 3 delete from GLS
\Classes\BookDataCalc_Purch_RU\pack 1 3 delete from GLS
\Classes\BookDataCalc_Purch_RU\unpack 1 3 delete from GLS Error \Classes\CostAllocationPost_RU\newFromCaller 19 32 Operand types are not compatible with the operator. Error \Classes\CostAllocationPostOverhead_RU\adjustInvoice 21 52 The table does not contain this field. Error \Classes\CostAllocationPostOverhead_RU\runPost 8 10 The class CostAllocationPostOverhead_RU does not contain this function.
\Classes\CustVendExchAdj\classDeclaration 35 61 SEKL - ANALYZE USAGE OF THIS VARIABLE Error \Classes\RDeferralsProposalWritingOff\createJournalLines 66 101 findFirstType is not a class function. Error \Classes\RPayCreateDeferrals\checkDeferralsProfile 11 26 The table does not contain this field. Error \Classes\RPayCreateDeferrals\initDeferralAmount 3 5 Variable RDeferralsBookAmount has not been declared. Error \Classes\RPayCreateDeferrals\initDeferralModel 3 5 Variable RDeferralsBookAmount has not been declared. Error \Classes\RPayCreateDeferrals\postDeferralsTrans 19 72 The enumeration does not exist.
\Classes\RPayPFReportXML_SZV6\DEL_docQty 1 3 delete Warning \Classes\RPayReportRSV1_2010\getEmplQtyAvg 40 61 Assignment/Comparison loses precision.
\Data Dictionary\Tables\CustParameters\Methods\numRefCustAdvanceInvoiceId_CZ 1 3 delete from GLS
\Data Dictionary\Tables\CzCustAdvanceInvoiceTable\Methods\euroTriangulation 1 3 delete
\Data Dictionary\Tables\CzCustAdvanceInvoiceTable\Methods\exchRate 1 3 delete
\Data Dictionary\Tables\CzCustAdvanceInvoiceTable\Methods\exchRateSecondary 1 3 delete Error \Data Dictionary\Tables\RPayAverageEarnEmplPeriodTable\Methods\allowReverseDeferral 11 70 The enumeration does not exist. Error \Data Dictionary\Tables\RPayAverageEarnEmplPeriodTable\Methods\reverseDeferrals 7 5 Variable RDeferralsTransactionReversal has not been declared. Error \Data Dictionary\Tables\RPayTrans\Methods\checkDeferrals 14 71 The enumeration does not exist. Error \Data Dictionary\Tables\RPayTrans\Methods\reverseDeferrals 8 5 Variable RDeferralsTransactionReversal has not been declared.
\Data Dictionary\Tables\SalesLine\Methods\originalInvoiceId_CZ 1 3 This method is to be removed.
\Reports\CzSalesAdvanceInvoice_Table\Methods\classDeclaration 1 3 rename report to CustAdvanceInvoice_Table_CZ
\Reports\CzSalesAdvanceInvoice_Table\Methods\classDeclaration 2 3 rename menu item CzSalesAdvanceInvoice_Table
Последний раз редактировалось AX2009; 19.12.2010 в 21:32.
ax2009, payroll, rollup
mbsturk: Ax 2009 Rollup 4 Version Checker Blog bot DAX Blogs 0 29.04.2010 17:05
Часовой пояс GMT +3, время: 10:45.
