You will need to re-install Visual Studio 20087 SP1 *after* installing Team Explorer 2008; you can then apply the TFS2010 Forward Compatibility Hotfix (KB974558) - I've had exactly the same problem on Windows Server 2003 and this fixed the issue
http://blogs.msdn.com/b/granth/archi...o-connect.aspx |
MCT
My problem is VS 2010.
I know that if I have vs 2008, only I need to install KB974558. And more TFS 2010 does not support oficially. That means I may do not have any error at first, but lately some futures may not work.
Axapta book for developer |
Перенести ветку в DAX in English ?
-ТСЯ или -ТЬСЯ ? |
Теги |
ax2009, team foundation server, tfs |
