Старый 24.01.2011, 13:55   #1
Denicce is offline
Denicce
Можно так сделать. Хоть какое-то "удобство".
новый метод \Classes\Global\queryValueEnum
static str queryValueEnum(int _value, Name _dsName, FieldName _fieldName)
    return strfmt("(%1.%2 == %3)", _dsName, _fieldName, _value);
static void testQueryPack(Args _args)
    Query                q1, q2;
    QueryBuildDataSource qbds1, qbds2;
    container            con;
    q1    = new Query();
    qbds1 = q1.addDataSource(tablenum(InventTrans));
    qbds1.addRange(fieldnum(InventTrans, StatusIssue)).value(queryValueEnum(StatusIssue::None, qbds1.name(), "StatusIssue"));
    qbds1.addRange(fieldnum(InventTrans, StatusIssue)).value(queryValueEnum(StatusIssue::Sold, qbds1.name(), "StatusIssue"));
    qbds1.addRange(fieldnum(InventTrans, StatusReceipt)).value(queryValueEnum(StatusReceipt::None,      qbds1.name(), "StatusReceipt"));
    qbds1.addRange(fieldnum(InventTrans, StatusReceipt)).value(queryValueEnum(StatusReceipt::Purchased, qbds1.name(), "StatusReceipt"));
    info(qbds1.toString());
    con = q1.pack();
    q2  = new Query(con);
    qbds2 = q2.dataSourceTable(tablenum(InventTrans));
    info(qbds2.toString());
query, баг, ax3.0
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Service Pack 1 Released Blog bot DAX Blogs 5 21.11.2008 17:00
palleagermark: Sample union query from AX 2009 Blog bot DAX Blogs 0 11.07.2008 20:05
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 28.10.2006 16:40
Проблема с составлением Query axaLearner DAX: Программирование 10 01.12.2005 15:00
Часовой пояс GMT +3, время: 10:57.
