Старый 13.05.2011, 10:34   #6
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Сообщение от Poleax Посмотреть сообщение
Что делать с WARNING: File ax_trace.mof does not contain #PRAGMA AUTORECOVER.?
Добавил
PHP код:
mofcomp.exe -Autorecover aos_trace.mof
mofcomp
.exe -Autorecover ax_trace.mof
Код:
D:\AX Trace>mofcomp.exe -Autorecover aos_trace.mof
Microsoft (R) MOF Compiler Version 6.1.7600.16385
Copyright (c) Microsoft Corp. 1997-2006. All rights reserved.
Parsing MOF file: aos_trace.mof
MOF file has been successfully parsed
Storing data in the repository...
Done!
D:\AX Trace>mofcomp.exe -Autorecover ax_trace.mof
Parsing MOF file: ax_trace.mof
Done!
Посмотрю как работает.
P.S. http://myitforum.com/cs2/blogs/jgilb...r-command.aspx
http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx
trace parser
Preston.Larimer: Item import from CSV file made easy (Kinda) Blog bot DAX Blogs 3 15.11.2010 12:26
fed: Tracing in Dynamics AX 4 and 2009 Blog bot DAX Blogs 0 10.03.2010 20:05
emeadaxsupport: Warning when loading license file - License value for ID 2024 has not been created (or License value for ID 2025 has not been created) Blog bot DAX Blogs 0 12.01.2010 04:44
hariprasadp: Import Excel file data in to dynamics AX through Dynamics AX Blog bot DAX Blogs 0 17.12.2009 20:05
Dynamics AX: Trace Parser (beta) tool for Microsoft Dynamics™ AX 4.0 Blog bot DAX Blogs 0 20.03.2007 14:40
Часовой пояс GMT +3, время: 12:14.
