Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 17.06.2011, 14:35   #2
3,684 / 5813 (201) ++++++++++
Well... you can set a trigger on the SqlDictionary table insert/delete to get an alert when a new field (or table/view!) is kinda created "physically" in the database (or when a table/view/field is dropped). In a database trigger you'll have to somehow connect to an AOS, enumerate user session objects and find an information about a user session that is currently using the database session in which a trigger is running (by the session SPID or something). Then you can find a record with this user session id in the SysClientSessions table and find out the userId.
Note that this way you can't monitor changes that don't alter the database scheme, e.g. changes in a field's label or EDT.
Последний раз редактировалось gl00mie; 17.06.2011 в 14:38.
axdaily: SQL temporary tables in AX 2012 Blog bot DAX Blogs 25 06.05.2011 10:18
sumitsaxfactor: AOSAuthorization property on tables Blog bot DAX Blogs 0 06.05.2011 02:19
Prabhats: DAX 2009: Temporary Tables in Enterprise Portal Blog bot DAX Blogs 0 27.04.2011 11:11
axhelper: How to Use Temporary tables in reports Blog bot DAX Blogs 0 29.09.2010 18:05
Microsoft Dynamics AX AIF: Sending Outbound Documents Automatically Blog bot DAX Blogs 0 31.03.2008 11:05
Часовой пояс GMT +3, время: 07:06.
