Старый 28.12.2011, 00:05   #6
Aliwer is offline
Aliwer
Подскажите пожалуйста, из за чего ошибка.
Компилятору не нравиться последняя строка -> proxy.Create(sq);
и выдает такую ошибку:
An unhandled exception of type 'System.ServiceModel.FaultException`1' occurred in Microsoft.Xrm.Sdk.dll
Additional information: The expected returnedTypeCode 3 did not match the return type 1 on fetchXml
Вот код:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.ServiceModel;
using System.ServiceModel.Description;
using System.Runtime.Serialization;
// These namespaces are found in the Microsoft.Xrm.Sdk.dll assembly
// found in the SDK\bin folder.
using Microsoft.Xrm.Sdk;
using Microsoft.Xrm.Sdk.Client;
using Microsoft.Xrm.Sdk.Query;
namespace CreateView
    class Program
        static void Main(string[] args)
            // Подключаемся к CRM
            ClientCredentials credentials = new ClientCredentials();
            credentials.Windows.ClientCredential = new System.Net.NetworkCredential("Администратор", "12345", "crm.dev");
            Uri uri = new Uri("http://192.168.57.50:80/NoName/XRMServices/2011/Organization.svc");
            OrganizationServiceProxy proxy = new OrganizationServiceProxy(uri, null, credentials, null);
            proxy.ServiceConfiguration.CurrentServiceEndpoint.Behaviors.Add(new ProxyTypesBehavior());
            IOrganizationService service = (IOrganizationService)proxy;
            // Create the view.
            string layoutXml = @"<grid name='resultset' object='1' jump='accountid' select='1' preview='1' icon='1'>
    <row name='result' id='accountid'>
    <cell name='name' width='150' />
    <cell name='customerid' width='150' />
    <cell name='primarycontactid' width='150' />
    <cell name='telephone1' width='150' />
     </row>
</grid>";
            //fetch example
            string fetchXml = @"<fetch version='1.0' output-format='xml-platform' mapping='logical' distinct='false'>
<entity name='account'>
<attribute name='name' />
<attribute name='primarycontactid' />
<attribute name='telephone1' />
<attribute name='accountid' />
<order attribute='name' descending='false' />
<filter type='and'>
<condition attribute='name' operator='eq' value='qwe' />
</filter>
</entity>
</fetch>";
            SavedQuery sq = new SavedQuery();
            sq.Name = "A New Custom Public View";
            sq.Description = "A Saved Query created in code";
            sq.ReturnedTypeCode = "opportunity";
            sq.FetchXml = fetchXml;
            sq.LayoutXml = layoutXml;
            sq.QueryType = 0;
            Console.WriteLine("A new view");
            proxy.Create(sq);
FetchXML multiple parameter Lud Dynamics CRM: Разработка 5 24.10.2011 06:58
Не работает SQL запрос ipok Dynamics CRM: Разработка 8 30.01.2011 11:18
jamesdowney: Pulling Attribute Values into Variables from FetchXML Result Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Ronald Lemmen: Using Advanced Find for FetchXML builder v4.0 Blog bot Dynamics CRM: Blogs 0 16.02.2009 19:05
Запрос в SQL AlekseyS Dynamics CRM: Разработка 1 26.08.2008 11:01
Часовой пояс GMT +3, время: 18:59.
