16.03.2012, 07:11 | #1 |
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of Safari 5.1.2 with Dynamics AX 2012
Источник: http://blogs.technet.com/b/dynamicsa...s-ax-2012.aspx
============== Dynamics AX Sustained Engineering is proud to announce the following compatibility: Product Dynamics AX Version Apple Safari 5.1.2 on Windows and Mac OS Dynamics AX 2012 To use the Safari browser, you must install Microsoft Dynamics AX hotfix 2686124. Enterprise Portal supports Safari only for end user tasks in the portal. Enterprise Portal does not support Safari for developer or system administrator tasks. The System requirements of Dynamics AX 2012 is in the process of being updated on Customer Source and Partner Source. Follow the Dynamics AX Sustained Engineering blog for the latest updates on the above. For further information, feel free to contact daxsecom@microsoft.com Источник: http://blogs.technet.com/b/dynamicsa...s-ax-2012.aspx
