Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 08.04.2012, 02:17   #1
ist is offline
ist
Invisible form
Hi Guys,
Is there any way to run AX form invisible.
I have the following case:
When the production order is reporting as finished I have to run ProdJournalTransBOM form for some reasons, but not in standard manner (through ProdJournalTable form), but I can't because ProdJournalTransBOM require (caller) formRun object to initialize itself. My idea is to run invisible ProdJournalTable form with the necessary args object and pass it as caller on the ProdJournalTransBOM form.
Regards,
Последний раз редактировалось ist; 08.04.2012 в 02:31.
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
emeadaxsupport: Users don't want to delete their usage data - but you've redeveloped the form - the solution Blog bot DAX Blogs 0 21.04.2011 22:11
dynamicsaxtraining: Quality management Blog bot DAX Blogs 0 12.02.2011 00:11
Kashperuk Ivan: Lookup form returning more than one value Blog bot DAX Blogs 0 29.01.2010 18:05
Часовой пояс GMT +3, время: 19:07.
