Старый 21.08.2012, 14:11   #1
axblog4u: Reading Selected Node in XML – Dynamics AX2012
Источник: http://axblog4u.wordpress.com/2012/0...namics-ax2012/
Case Study: Below a sample job is illustrated to read selected (multiple) nodes from a given XML.
private static void SR_ReadSelectedNode_XML(Filename fileName)
    #define.node('INFORMATION//ROWS/ROW')
    XmlDocument xmlDocument;
    XmlNode     xmlInformationNode;
    XmlNodeList xmlInformationsNodeList;
    XmlNodeList xmlChildNodeList;
    int         i;
    int         j;
    fileName                = @'C:\Projects\ReadNode.xml';
    xmlDocument             = xmlDocument::newFile(fileName);
    xmlInformationsNodeList = xmlDocument.documentElement()
                                         .selectNodes(#node);
    setPrefix("@SYS98689");
    for ( i = 0; i < xmlInformationsNodeList.length(); i++)
        xmlChildNodeList = xmlInformationsNodeList.item(i)
                                                  .childNodes();
        for (j = 0; j < xmlChildNodeList.length() ; j++)
            xmlInformationNode = xmlChildNodeList.item(j);
            if (xmlInformationNode.baseName() == 'DETAILS')
                info(xmlInformationNode.innerXml());
                break;
Последний раз редактировалось Poleax; 21.08.2012 в 14:42.
axblog4u: Display Web Image Content in Forms using Dynamics AX2012 Blog bot DAX Blogs 0 28.05.2012 19:12
axblog4u: Dynamics AX2012: Create Custom Service using X++ Blog bot DAX Blogs 0 24.01.2012 21:11
Часовой пояс GMT +3, время: 03:52.
