Старый 11.09.2012, 18:11   #1
25,643 / 848 (80) +++++++
ax-erp: How to extract Date value from a DateTime field
Источник: http://microsoft-dynamics-ax-erp.blo...-datetime.html
In this post I show how to extract Date value from a DateTime field.
To do this, we need to use System.DateTime.
Please refer to the sample Job below. It will retrieve a Date value from createdDateTime field on a purchaseOrder record.
static void getDate(Args _args)
{ System.DateTime _dateTime; Date _date; PurchTable _purchTable; ;
_purchTable = PurchTable::find("PO000008");
_dateTime = System.DateTime::Parse(dateTime2str(_purchTable.createdDateTime));
_date = _dateTime.get_Date();
info(date2str(_date,-1,-1,-1,-1,-1,-1));
Note: if you get "Request for the permission of type 'InteropPermission' failed." error, you need to use InteropPermission class:
Date _date;
InteropPermission intPerm = new InteropPermission(InteropKind::ClrInterop);
intPerm.assert();
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
dynamics-ax: Expert SSRS with AX Tip from Michael Stashwick Blog bot DAX Blogs 0 14.01.2011 05:18
emeadaxsupport: How to open an AX form from your own help Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 02:13.
