Старый 18.10.2012, 10:31   #3
Player1 is offline
Player1
306 / 137 (5) +++++
вот код
    XmlDocument doc = new XMLDocument();
    XmlElement  nodeXml;
    XmlElement  nodeTable;
    XmlElement  nodeItem;
    XmlElement  nodeExtItem;
    XmlElement  nodeName;
    XmlElement  nodeItemName;
    XmlElement  nodeModelGroup;
    XmlElement  nodeDimGroup;
    InventTable inventTable;
    #define.filename("d:\\xml\\test.xml")
    doc     = XmlDocument::newBlank();
    nodeXml = doc.createElement("xml");
    doc.appendChild(nodeXml);
    while select inventTable
        nodeTable = doc.createElement(tablestr(InventTable));
        nodeTable.setAttribute( fieldstr(InventTable, RecId), int2str(inventTable.RecId) );
        nodeXml.appendChild(nodeTable);
        nodeExtItem = doc.createElement( fieldstr(InventTable, ExternalItemId) );
        nodeExtItem.appendChild( doc.createTextNode(inventTable.ExternalItemId) );
        nodeTable.appendChild(nodeExtItem);
        nodeItem = doc.createElement( fieldstr(InventTable, ItemId) );
        nodeItem.appendChild( doc.createTextNode(inventTable.ItemId) );
        nodeTable.appendChild(nodeItem);
    doc.save(#filename);
Create XML-Export with AIF ideveloper DAX in English 8 05.03.2012 10:18
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 19.10.2008 18:05
Dynamics AX FAQ: How to import and export data in XML format using Axd classes? Blog bot DAX Blogs 0 18.06.2008 20:05
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 25.03.2008 03:58
Dynamics AX FAQ: How to import and export data in XML format using Axd classes? Blog bot DAX Blogs 0 04.03.2008 06:13
Часовой пояс GMT +3, время: 06:21.
