18.10.2012, 19:11 | #1 |
ax-erp: How to Set the Query Range on a SSRS Report
Источник: http://microsoft-dynamics-ax-erp.blo...rs-report.html
============== If the SSRS report is build with AOT query SRSReportRun reportRun = new SRSReportRun(‘Report1.AutoDesign1′); // Create variables for setting the range for the query. Query query; QueryBuildDataSource queryBuildDataSource; QueryBuildRange queryBuildRange; int i; // Check if the query will return data. if (reportRun.init()) { // Find the Cust query. query = reportRun.reportQuery(‘Cust’); // query name of the report if (query != null) { // Get the Customers data source. queryBuildDataSource = query.dataSourceName(‘Customers’); if (queryBuildDataSource != null) { queryBuildRange = queryBuildDataSource.addRange(fieldName2Id(queryBuildDataSource.table(), ‘AccountNum’)); queryBuildRange.value(’4000′); } } // Save the report settings. reportRun.saveSettings(); // Run the report. reportRun.run(); } If the report is build with Data contract Here is an example which comes from the AOT – Classes – CustPamnManOutputReportController – preRunModifyContract method: protected void preRunModifyContract() { Query reportQuery; SrsReportRdlDataContract rdlContract; rdlContract = this.parmReportContract().parmRdlContract(); // may be some changes require here if the report is running from some job. if (rdlContract.getValue(#reportParameter)) { custPaymManFile.reportDate(systemdateget()); custPaymManFile.status(PaymManRemittanceStatus::Sent); } this.processReport(custPaymManFile); reportQuery = new Query(querystr(CustPaymManOutputReport)); SRSReportHelper::addParameterValueRangeToQuery( reportQuery, tablenum(TmpPaymManOutputReport), fieldnum(TmpPaymManOutputReport, SessionId), this.currentSessionId()); this.parmReportContract().parmQueryContracts().insert(queryKey, reportQuery); } Источник: http://microsoft-dynamics-ax-erp.blo...rs-report.html
