07.01.2013, 08:32 | #1 |
daxmusings: Multi-select on form datasource grid : MultiSelectionHelper
Источник: https://community.dynamics.com/produ...ionhelper.aspx
============== In Dynamics AX it has traditionally been somewhat cumbersome to iterate the selected records on a form datasource. The main issue is that there is a difference in iterating depending on how and what the user has selected! For example, I have a simple...(read more) Источник: https://community.dynamics.com/produ...ionhelper.aspx
08.01.2013, 13:44 | #2 |
But of course, there's a better way in Dynamics AX 2012. A class called "MultiSelectionHelper" will do the heavy lifting for you.
За это сообщение автора поблагодарили: Lemming (1). |
