Старый 05.02.2013, 20:27   #8
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2161 (81) +++++++++
Все верно. Стр. 91 руководства по установке:
Select a web site for the Help server
The Help server must be installed on a web site in Internet Information Services (IIS). You can create a new
web site for the Help server, or you can use an existing site. The following sections describe these options.
Create a new web site
If you want to create a new web site for the Help server, see the IIS documentation for information about
how to create a web site.
Use an existing web site
You can install the Help server on an existing web site that is used by other applications. However, you
must verify that neither Microsoft SharePoint Foundation 2010 nor Microsoft SharePoint Server 2010 is
running on the same site.
Ivanhoe as is..
За это сообщение автора поблагодарили: MikeR (3).
ax2012
Gareth Tucker: Scribe Insight and Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 06.05.2012 02:18
Часовой пояс GMT +3, время: 20:11.
