Старый 19.04.2013, 20:13   #1
furnemont: CRM 2011: Bad ‘setFormMode’ error!
Источник: http://www.furnemont.eu/2013/04/crm-...ormmode-error/
The other day, I was puzzled by a weird problem coming from a “Go to URL” action in a CRM sub-report.
The link was constructed correctly by using the following line of code:
Parameters!CRM_URL.Value & “?ID={“& Fields!new_bookingid.Value.ToString() &”}&LogicalName=new_booking”
which was rendered as:
https://crm.site.com/main.aspx?etn=n...e=entityrecord
Notice how the ID has been replicated twice? Now the form was opening correctly but no Javascript was called after I updated the fields, which is why I fired up the IE developer tools and debugged the form scripts to discover an horrible Javascript error: Object doesn’t support property or method ‘setFormMode’
I then remembered that my client CRM server was on Update Rollup 7, so after having read the following forum post http://social.microsoft.com/Forums/e...6-a2b7b91f3256, I knew the only solution was to update the server!
Hope this helps someone.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 13 Blog bot Dynamics CRM: Blogs 0 27.03.2013 22:12
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 7 Blog bot Dynamics CRM: Blogs 0 27.03.2012 02:11
Часовой пояс GMT +3, время: 01:35.
