Старый 26.04.2013, 13:01   #2
S.Kuskov is offline
S.Kuskov
3,449 / 1792 (66) ++++++++
Вопрос в том почему срабатывает это условие?
// If replacing the document, remove all sub-records that were not replaced.
if (axdBase.topRecordAction() == AxdRecordAction::Replace)
    this.deleteUntouchedSubRecords(currentEntity,_mapPolicy);
aif, ax4.0
AIF: How to serialize int/real properties with 0/0.00 values via AIF outbound integration Blog bot DAX Blogs 0 08.05.2012 04:13
axinthefield: The AIF processing services used by each of the AIF adapters in AX 2009 Blog bot DAX Blogs 0 27.05.2011 05:12
Aku: Assistent für AIF-Dokumentendienste und Tabellen mit InventDimId Blog bot DAX Blogs 0 22.04.2011 17:11
daxdilip: How to: Configure Dynamics AX AIF Services to listen for SSL Requests (https) Blog bot DAX Blogs 0 23.01.2011 10:12
Dianne Siebold: AIF Top Ten Blog bot DAX Blogs 1 22.04.2008 11:19
Часовой пояс GMT +3, время: 05:36.
