Старый 21.06.2013, 11:29   #1
Swordec is offline
Swordec
При попытке сделать разноску накладной и затем вывести ее на печать с помощью пакетной обработки, выдает ошибку:
System.NullReferenceException: Object reference not set to an instance of an object.
   at Microsoft.Dynamics.Ax.Xpp.Set.elements()
   at Dynamics.Ax.Application.FormletterJournalPrint.Printjournal(Set _journalList) in FormletterJournalPrint.printJournal.xpp:line 26
   at Dynamics.Ax.Application.SalesInvoiceJournalPrint.Printjournal(Set _journalList) in SalesInvoiceJournalPrint.printJournal.xpp:line 13
   at Dynamics.Ax.Application.FormLetterServiceController.Afteroperationprint() in FormLetterServiceController.afterOperationPrint.xpp:line 20
   at Dynamics.Ax.Application.FormLetterServiceController.Afteroperationbody() in FormLetterServiceController.afterOperationBody.xpp:line 6
   at Dynamics.Ax.Application.SalesFormLetter.Afteroperationbody() in SalesFormLetter.afterOperationBody.xpp:line 6
   at Dynamics.Ax.Application.SalesFormLetter_Invoice.Afteroperationbody() in SalesFormLetter_Invoice.afterOperationBody.xpp:line 6
   at Dynamics.Ax.Application.FormLetterServiceController.Afteroperation(SysOperationExecutionMode _executionMode, AifAsyncResult _asyncResult) in FormLetterServiceController.afterOperation.xpp:line 7
   at Dynamics.Ax.Application.SysOperationServiceController.Run() in SysOperationServiceController.run.xpp:line 70
   at Dynamics.Ax.Application.FormLetterServiceController.Run() in FormLetterServiceController.run.xpp:line 3
   at Dynamics.Ax.Application.SalesFormLetter.Run() in SalesFormLetter.run.xpp:line 72
   at Dynamics.Ax.Application.SalesFormLetter_Invoice.Run() in SalesFormLetter_Invoice.run.xpp:line 6
   at Dynamics.Ax.Application.BatchRun.runJobStaticCode(Int64 batchId) in BatchRun.runJobStaticCode.xpp:line 54
   at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in BatchRun.runJobStatic.xpp:line 13
   at BatchRun::runJobStatic(Object[] )
   at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
   at BatchIL.taskThreadEntry(Object threadArg)
Последний раз редактировалось Swordec; 21.06.2013 в 11:51.
ax2012, cil, excel, open xml, баг, ошибка, пакетная обработка, пакетный сервер
Двухсторонняя печать в Excel EfimV DAX: Программирование 2 15.11.2010 13:26
Печать страниц Excel на отдельные листы kuvg DAX: Программирование 3 02.08.2010 10:55
Запрет на печать и сохранение документов doc, xls. 3oppo DAX: Программирование 23 27.05.2010 17:07
Печать документов по Заказам, Закупкам Swetik DAX: Функционал 8 11.04.2008 20:07
Печать отчета в Excel. Axapta 3.0 Fedr Kuzmich DAX: Функционал 2 19.05.2004 18:26
Часовой пояс GMT +3, время: 05:37.
