Старый 08.10.2013, 22:11   #1
25,643 / 848 (80) +++++++
emeadaxsupport: EMEA Dynamics AX Monthly webinars - get the latest information about AX delivered by Support- and Escalation engineers.
Источник: http://blogs.msdn.com/b/axsupport/ar...engineers.aspx
Dynamics AX monthly webinar series
This webinar-series is delivered by Support engineers who works in the domains for AX Technical (code, upgrade, setup etc.), AX Supply chain management (SCM) (Production,Warehouse management etc.) and AX Finance (the rest) in the Service and Support organization.
The agenda will vary from webinar to webinar, so all partners that are registered for the event series, will get an agenda for the particular webinar some days before, this to enable you to determine on forehand if you will attend the event. The subjects will
mostly be:
  • Known issues,
  • Latest hotfixes
  • Design limitations
  • "Uncharted territory"
  • Tips & Tricks
  • New features
Date and time:
Always the last Thursday in a month, beginning in November, from 4:00 to 5:00 CET - November 28th 2013 to June 26th 2014 (December excluded)
When you register forthe event at Partner Learning Center, make sure that you register for all the webinars.
Register here
axinthefield: Top 10 issues discovered from Dynamics AX Health Check Blog bot DAX Blogs 0 27.06.2013 19:11
crminthefield: Introducing the Dynamics CRM Support Blog! Blog bot Dynamics CRM: Blogs 0 15.08.2012 22:12
axinthefield: SQL Server Trace Flags for Dynamics AX Blog bot DAX Blogs 0 23.11.2010 21:11
Часовой пояс GMT +3, время: 08:41.
