#2 |
dynamicscare: Using Export To Excel in Dynamics AX to Create Reporting Data Sources
Источник: http://dynamicscare.com/blog/using-e...-data-sources/
============== The Export to Excel button may not seem like the most impressive feature of Dynamics AX, but don’t be fooled. If you look closely, you will notice that the when the data is exported to Excel, the data is still linked to Dynamics AX through the Excel Add-In, which means that once it is in [...] Источник: http://dynamicscare.com/blog/using-e...-data-sources/
