Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 16.12.2013, 08:47   #1
3,684 / 5803 (201) ++++++++++
Сообщение от ist Посмотреть сообщение
One of ASP.net MVC application forms has a problem when the AX client is started. When I stop AX there is no problem. When AX works with one AOS (without load balancer) everithing is OK.
Can you give more details about the situation "when the AX client is started"? Where is it started, which AOS does it connect to? And actually is it Windows Rich AX client?
Старый 16.12.2013, 10:24   #2
ist is offline
ist
Hi,
I have 5 virtual machine on which I have installed 5 Application Object Server's.
AOS0, AOS1, AOS2, AOS3, AOS4, AOS5. AOS0 is load balancer. I started AX rich windows client on the virtual mashine where load balancer resides. The AX can connect to AOS1, AOS2, AOS3, AOS4. It deppends on load balancer. In current case Ax client is connected to AOS2 as I can see in online users dialog. Business connector configuration points to Load balancer AOS0. Sometimes there is a session to bcproxy user connected to AOS1 when I put request to asp.net mvc application in the browser on the mashine whit AOS1. Somethimes there is not.
ist.
aif
daxdilip: Fiddler - Good tool to check EP web page, custom websites, performance and AIF Web services Blog bot DAX Blogs 0 04.12.2010 14:11
axaptasource: Fiddler – Good tool to check EP web page, custom websites, performance and AIF Web services Blog bot DAX Blogs 0 04.12.2010 14:11
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Arijit Basu: Infopath, Web Services & AX Integration Blog bot DAX Blogs 0 04.05.2008 23:05
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Часовой пояс GMT +3, время: 06:27.
