Старый 18.12.2013, 02:13   #1
25,644 / 848 (80) +++++++
Malaysia: Duplicate Object
Источник: http://axmas.blogspot.com/2013/12/duplicate-object.html
Duplicate type with name 'Dynamics.Ax.application.' in assembly
'Dynamics.Ax.application, version=6.0.947.280, culture...
You can try the solution:
1. import twice the object, second time system will prompt you object exist, overwrite it? click Yes to all.
2. Full CIL
Ошибка при публикации настроек ms crm 4.0 lin2nil Dynamics CRM: Администрирование 27 25.09.2014 12:58
Malaysia: Building a query object Blog bot DAX Blogs 0 06.11.2012 15:11
a33ik: MS CRM 2011: Error during creation of Account record - System.Data.SqlClient.SqlException (0x80131904): Cannot insert duplicate key row in object 'dbo.EmailSearchBase' with unique index 'ndx_for_forward_update' Blog bot Dynamics CRM: Blogs 0 25.04.2012 03:18
kamalblogs: Setting default object owner as Object creator in Window server 2008 for AIF in Dynamics Ax Blog bot DAX Blogs 1 04.08.2010 14:24
Malaysia: Who Modified my Object Blog bot DAX Blogs 0 09.07.2009 02:05
Часовой пояс GMT +3, время: 06:09.
