Старый 12.02.2014, 15:11   #1
25,644 / 848 (80) +++++++
atinkerersnotebook: Synchronize Your Contacts Between Dynamics AX And Outlook And Back Again
Источник: http://atinkerersnotebook.com/2014/0...nd-back-again/
Originally posted on Dynamics AX Tip Of The Day:
If you have linked Dynamics AX with your local version of Microsoft Outlook, then you have probably ran the synchronization that adds all of the appointments, tasks, and also the contacts to Outlook. But there is a more powerful option that allows you to synchronize not only from Dynamics AX and Outlook, but with Outlook back to Dynamics AX giving you an even more useful form of contact synchronization.This is a great way to keep your contacts up to date, and also to populate Dynamics AX with all of your contact data without having to key in all of the people by hand, and also keep it up to date because it synchronizes both ways.
Remember, a contact does not become less useful if you share it with your friends.
View original
Dynamics AX: AX Solution Outlook: GRC: The Next Big Thing in Dynamics AX 2009 Blog bot DAX Blogs 0 11.02.2008 08:28
Dynamics AX: Interview with Steen Andreasen 2007 Blog bot DAX Blogs 0 19.09.2007 21:42
Часовой пояс GMT +3, время: 09:48.
