Старый 25.03.2014, 11:11   #1
25,644 / 848 (80) +++++++
Malaysia: Adding FileNameOpen Extended Data Type to a Form
Источник: http://axmas.blogspot.com/2014/03/ad...data-type.html
After add EDT FileNameOpen to form using New -> stringEdit,
[IMG]https://images-blogger-opensocial.googleusercontent.com/gadgets/proxy?url=http%3A%2F%2F4.bp.blogspot.com%2F-ZRK7jrAmF4A%2FUzDqDveT6pI%2FAAAAAAAAAUM%2F6ZgBA-10oh8%2Fs1600%2Fattachment.png&container=blogger&gadget=a&rewriteMime=image%2F*[/IMG]
add some form methods:
str fileNameLookupFilename()
return '';
str fileNameLookupTitle()
return "@SYS53008";
str fileNameLookupInitialPath()
return '';
container fileNameLookupFilter()
return ['All files','*.*'];
After get the file path, call insert method:
public void AvInsertAttachment(filename file, int i)
DocuRef docuRef;
DocuActionArchive archive;
if(file)
ttsbegin;
docuRef.clear();
docuRef.RefRecId = DirPartyEntity.RecId;
docuRef.RefTableId = tableNum(CustTable);
docuRef.RefCompanyId = DirPartyEntity.dataAreaId;
docuRef.Name = strFmt("Consultant Attachment %1", i);
docuRef.TypeId = 'File';
docuRef.insert();
archive = new DocuActionArchive();
archive.add(docuRef, file);
ttsCommit;
За это сообщение автора поблагодарили: NoTimeToCry (1).
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 19:31.
