Старый 26.03.2014, 16:11   #1
atinkerersnotebook: Add SharePoint Documents Libraries As Menu Links
Источник: http://atinkerersnotebook.com/2014/0...as-menu-links/
Originally posted on Dynamics AX Tip Of The Day:
Storing documents within SharePoint is cool. It allows you to browse through the documents, it allows you to have version control, it allows you to add metadata that you can use to search for documents, it does everything. The problem is that if you work in the AX client all the time, then you have to switch out of the application in order to view all the related documents. Don’t worry. If you want to access all of the documents from within Dynamics AX then you can add it to the menu.Now all of the Axoraphobiacs out there don’t have to leave the application all day.
View original 479 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
Часовой пояс GMT +3, время: 22:46.
