Старый 03.04.2014, 15:11   #1
atinkerersnotebook: Copy Data From One Partition To Another Using The Data Import Export
Источник: http://atinkerersnotebook.com/2014/0...import-export/
Originally posted on Dynamics AX Tip Of The Day:
Creating new partitions is a great way to create new instances of Dynamics AX without the overhead of creating new databases, and installing new AOS servers, because it piggybacks on the existing infrastructure you have. But it also means that you need to set up all of the data in the partition because it start’s off as a blank system… or do you? Dynamics AX has an inbuilt export and import function that allows you to export out all of the data in one partition and then import it into another.
Duplication has never been so easy.
View original 559 more words
atinkerersnotebook: Using Export To Excel in Dynamics AX to Create Reporting Data Sources Blog bot DAX Blogs 1 12.10.2013 01:13
dynamicscare: Using Power BI to Analyze Your Dynamics AX Data Blog bot DAX Blogs 1 06.10.2013 18:11
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Excel to Copy Data from One Company to Another Blog bot DAX Blogs 0 19.07.2013 15:11
Часовой пояс GMT +3, время: 23:10.
