Старый 22.04.2014, 14:42   #2
kalina is offline
kalina
25 / 16 (1) ++
Есть такой Query. Мне его дал знакомый, который не просто в SQL понимает, но и знает, что можно делать в базе данных с точки зрения CRM. Я проверял только на сервере разработки. Гарантировать безопасность использования этого Query не могу. Если решитесь использовать, и будут проблемы, буду рад, если поделитесь информацией.
Код:
--Description : This script reorganizes and rebuilds the index if the fragmentation level is higher the given threshold
-- You can define the threshold for reorganize as well as for rebuild and script will work accordingly
-- INPUTS : @fillfactor - While rebuilding index what would be FILLFACTOR for new index
-- @FragmentationThresholdForReorganizeTableLowerLimit - Fragmentation Level lower threshold to check for reorganizing the table, if the fragmentation is higher than this level, it will be considered for reorganize
-- @@FragmentationThresholdForRebuildTableLowerLimit - Fragmentation Level lower threshold to check for rebuilding the table, if the fragmentation is higher than this level, it will be considered for rebuild
-- NOTES : PRINT statements are all queued up and don't show up until the entire script is printed. However, there is an alternative to PRINTing messages.
-- You can raise an error that isn't really an error (code of 0) and you'll get the same effect--message will be printed immediately.
DECLARE @cmd NVARCHAR(1000)
DECLARE @Table VARCHAR(255)
DECLARE @SchemaName VARCHAR(255)
DECLARE @IndexName VARCHAR(255)
DECLARE @AvgFragmentationInPercent DECIMAL
DECLARE @fillfactor INT
DECLARE @FragmentationThresholdForReorganizeTableLowerLimit VARCHAR(10)
DECLARE @FragmentationThresholdForRebuildTableLowerLimit VARCHAR(10)
DECLARE @Message VARCHAR(1000)
SET NOCOUNT ON
--You can specify your customized value for reorganize and rebuild indexes, the default values
--of 10 and 30 means index will be reorgnized if the fragmentation level is more than equal to 10
--and less than 30, if the fragmentation level is more than equal to 30 then index will be rebuilt
SET @fillfactor = 90
SET @FragmentationThresholdForReorganizeTableLowerLimit = '4' -- Percent
SET @FragmentationThresholdForRebuildTableLowerLimit = '33.0' -- Percent
BEGIN TRY
-- ensure the temporary table does not exist
IF (SELECT OBJECT_ID('tempdb..#FramentedTableList')) IS NOT NULL
DROP TABLE #FramentedTableList;
SET @Message = 'DATE : ' + CONVERT(VARCHAR, GETDATE()) + ' - Retrieving indexes with high fragmentation from ' + DB_NAME() + ' database.'
RAISERROR(@Message, 0, 1) WITH NOWAIT
SELECT OBJECT_NAME(IPS.OBJECT_ID) AS [TableName], avg_fragmentation_in_percent, SI.name [IndexName],
schema_name(ST.schema_id) AS [SchemaName], 0 AS IsProcessed INTO #FramentedTableList
FROM sys.dm_db_index_physical_stats(DB_ID(), NULL, NULL, NULL , NULL) IPS
JOIN sys.tables ST WITH (nolock) ON IPS.OBJECT_ID = ST.OBJECT_ID
JOIN sys.indexes SI WITH (nolock) ON IPS.OBJECT_ID = SI.OBJECT_ID AND IPS.index_id = SI.index_id
WHERE ST.is_ms_shipped = 0 AND SI.name IS NOT NULL
AND avg_fragmentation_in_percent >= CONVERT(DECIMAL, @FragmentationThresholdForReorganizeTableLowerLimit)
ORDER BY avg_fragmentation_in_percent DESC
SET @Message = 'DATE : ' + CONVERT(VARCHAR, GETDATE()) + ' - Retrieved indexes with high fragmentation from ' + DB_NAME() + ' database.'
RAISERROR('', 0, 1) WITH NOWAIT
WHILE EXISTS ( SELECT 1 FROM #FramentedTableList WHERE IsProcessed = 0 )
BEGIN
  SELECT TOP 1 @Table = TableName, @AvgFragmentationInPercent = avg_fragmentation_in_percent,
  @SchemaName = SchemaName, @IndexName = IndexName
  --Reorganizing the index
  IF((@AvgFragmentationInPercent >= @FragmentationThresholdForReorganizeTableLowerLimit) AND (@AvgFragmentationInPercent < @FragmentationThresholdForRebuildTableLowerLimit))
  BEGIN
    SET @Message = 'DATE : ' + CONVERT(VARCHAR, GETDATE()) + ' - Reorganizing Index for [' + @Table + '] which has avg_fragmentation_in_percent = ' + CONVERT(VARCHAR, @AvgFragmentationInPercent) + '.'
    SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON [' + RTRIM(LTRIM(@SchemaName)) + '].[' + RTRIM(LTRIM(@Table)) + '] REORGANIZE'
    EXEC (@cmd)
    --PRINT @cmd
    SET @Message = 'DATE : ' + CONVERT(VARCHAR, GETDATE()) + ' - Reorganize Index completed successfully for [' + @Table + '].'
  END
  --Rebuilding the index
  ELSE IF (@AvgFragmentationInPercent >= @FragmentationThresholdForRebuildTableLowerLimit )
  BEGIN
    SET @Message = 'DATE : ' + CONVERT(VARCHAR, GETDATE()) + ' - Rebuilding Index for [' + @Table + '] which has avg_fragmentation_in_percent = ' + CONVERT(VARCHAR, @AvgFragmentationInPercent) + '.'
    SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON [' + RTRIM(LTRIM(@SchemaName)) + '].[' + RTRIM(LTRIM(@Table)) + '] REBUILD WITH (FILLFACTOR = ' + CONVERT(VARCHAR(3),@fillfactor) + ', STATISTICS_NORECOMPUTE = OFF)'
    EXEC (@cmd)
    --PRINT @cmd
    SET @Message = 'DATE : ' + CONVERT(VARCHAR, GETDATE()) + ' - Rebuild Index completed successfully for [' + @Table + '].'
  END
  UPDATE #FramentedTableList
  SET IsProcessed = 1
  WHERE TableName = @Table
  AND IndexName = @IndexName
END
select *
from #FramentedTableList */
END TRY
BEGIN CATCH
  PRINT 'DATE : ' + CONVERT(VARCHAR, GETDATE()) + ' There is some run time exception.'
  PRINT 'ERROR CODE : ' + CONVERT(VARCHAR, ERROR_NUMBER())
  PRINT 'ERROR MESSAGE : ' + ERROR_MESSAGE()
END CATCH
Последний раз редактировалось kalina; 22.04.2014 в 14:44.
Часовой пояс GMT +3, время: 07:42.
