Старый 12.05.2014, 13:27   #4
axotnik88 is offline
axotnik88
Не знаю как с Pos, но с клиентом мне помогло
First, Go to System Properties > Advanced Tab > Environment Variables > System Variables then click New.
Put "UserDnsDomain" on the Variable name. Put any value on the variable value.
run Registry Editor or regedit. go to
Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\ComputerName\ActiveComputerName
put any value on the value data.
Install AX.
Note: After Installing AX, change your ActiveComputerName in the Registry to your default computer name. Use the Computer Name in installing the AOS (computer name before changing the registry.)
http://community.dynamics.com/ax/f/33/t/102987.aspx
emeadaxsupport: AX for Retail 2012 R2: Password maintenance in the POS Blog bot DAX Blogs 0 18.01.2014 02:26
emeadaxsupport: AX 2012 R2 for Retail - Configuring POS for test mode with Dynamics Online payment service Blog bot DAX Blogs 0 11.10.2013 03:12
emeadaxsupport: AX for Retail 2012 R2: Using the Extensions folder for POS Customizations Blog bot DAX Blogs 0 27.09.2013 06:16
ax2012 r2: Как более правильно поменять компанию из под которой работает POS? MikeR DAX: Администрирование 2 22.07.2013 10:41
emeadaxsupport: AX for Retail 2012 R2: Adding a Custom User Control to the POS Blog bot DAX Blogs 0 27.02.2013 07:14
Часовой пояс GMT +3, время: 23:31.
