Старый 14.05.2014, 10:11   #1
mscrmblog: SharePoint 2013 Central Administration Ribbons Grayed Out
Источник: http://mscrmblog.net/2014/05/14/shar...ns-grayed-out/
Ribbons such as New Web Application, Properties on Service Applications (such as Managed Metadata Service)
The solution is to run ‘Central Administration’ as Administrator. Off course this being a 2012 R2 server i disabled the UAC prompting but this didn’t stop the ‘Run as Administrator’ prompt.
Run this powershell script to disabled the Run as Administrator prompt
Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "EnableLUA" -Value "0"Shutdown -r -t 0
mscrmblog: Configure send to connections in SharePoint 2013 Blog bot Dynamics CRM: Blogs 0 02.05.2014 09:12
mscrmblog: Microsoft reissues SharePoint 2013 Service Pack 1 Blog bot Dynamics CRM: Blogs 0 30.04.2014 09:11
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
axStart: Install enterprise portal on SharePoint 2013 Blog bot DAX Blogs 0 17.04.2013 03:25
Часовой пояс GMT +3, время: 06:46.
