Старый 26.06.2014, 17:08   #6
bio_unit is offline
bio_unit
Аватар для bio_unit
Сотрудники компании GMCS
119 / 77 (3) ++++
вот набросал на скорую джоб который находит VS проект для SSRS отчета
сделано по мотивам класса SysUpgrade60ReportProject
static void findSSRSReport(Args _args)
    #AOT
    #SysManagedCode
    #define.Report_ReferencesAttrib('Include')
    #define.ProjectContent("Project Content")
    str ssrsReportNameToFind = "TaxTable";
    str referencedProjects;
    TreeNode projectsRootNode = TreeNode::findNode(#VSProjectsAXModelPath);
    TreeNodeIterator iter = projectsRootNode.AOTiterator();
    TreeNode projectType = iter.next();
    TreeNode child;
    TreeNode childReports;
    VSProjectNode project = null;
    str projectPath;
    TreeNode projectContentNode;
    str aotName, projectContent;
    XmlDocument projectDoc;
    XmlNode projectRefNode;
    XmlNode xmlAttribute;
    str ssrsReportAotName, ssrsReportAotNameUpper;
    str xpath;
    XmlNodeList reportReferences;
    int nodeIndex;
    int basePathLen = strLen(#SSRSReportsPath + #AOTDelimiter);
    XmlNamespaceManager nsmgr;
    str namespaceUri = #MSBuildURL;
    str nsPrefix = 'cs';
    boolean found = false;
    str stripByteOrderInfo(str xml)
        int offset;
        // The xml string has some special chars and we need to trim it.
        if (xml)
            xml = strrtrim(strltrim(xml));
            offset = strscan(xml, @"<Project", 0, strlen(xml));
            // Remove everything before the "<?xml" tag
            if (offset > 0)
                xml = substr(xml, offset, strlen(xml));
        return xml;
    while(projectType)
        projectPath = projectType.treeNodePath();
        project = TreeNode::findNode(projectPath);
        if(project)
            projectContentNode = project.AOTfindChild(#VSProjectContentFolder);
            aotName = project.AOTname();
            // Find the project file node
            projectContentNode = projectContentNode.AOTfindChild(aotName + #VSProjectsAXModelProjectFileExtension);
            if(projectContentNode)
                // load the project file content from the project file node
                projectContent = projectContentNode.AOTgetSource();
                if (projectContent)
                    projectContent = stripByteOrderInfo(projectContent);
                    // load project file content into XML document.
                    projectDoc = new XmlDocument();
                    if (projectDoc.loadXml(projectContent))
                        // catalog report references in the XmlDocument
                        nsmgr = new XmlNamespaceManager(projectDoc.NameTable());
                        nsmgr.addNamespace(nsPrefix, namespaceUri);
                        xpath = strFmt('//cs:Compile/@Include[contains(., \'%1\')]/parent::node()', #SSRSReportsRootPath);
                        reportReferences = projectDoc.selectNodes(xpath, nsmgr);
                        for (nodeIndex = 0; nodeIndex < reportReferences.length(); nodeIndex++)
                            projectRefNode = reportReferences.item(nodeIndex);
                            xmlAttribute = projectRefNode.attributes().getNamedItem(#Report_ReferencesAttrib);
                            if (xmlAttribute)
                                // update attribute if new value is different
                                ssrsReportAotName = xmlAttribute.innerText();
                                ssrsReportAotName = strDel(xmlAttribute.innerText(), 0, basePathLen);
                                ssrsReportAotNameUpper = strUpr(ssrsReportAotName);
                                if (ssrsReportAotName == ssrsReportNameToFind)
                                    found = true;
                                    break;
        if (found)
            break;
    if (found)
        info (projectPath);
    else
        info ("Not found");
За это сообщение автора поблагодарили: mazzy (5), sukhanchik (4).
i-neti: В VS не показываются новые поля временной таблицы SSRS-отчета Blog bot DAX Blogs 0 18.06.2014 17:11
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
Работа отчета "Отчет об анализе расхождений"(InventCostVariances) irvin DAX: Программирование 3 19.08.2013 15:01
AX2012 корректная инициализация параметров отчета (SSRS) PavelX DAX: Программирование 1 24.11.2012 18:48
Часовой пояс GMT +3, время: 20:11.
