Старый 30.12.2015, 22:11   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Provide feedback on your AX 2012 R2 and R3 deployments
Источник: https://blogs.msdn.microsoft.com/axs...3-deployments/
Please take 5 minutes (for each survey) to share information about your existing AX 2012 R2 and R3 deployment and your update and upgrade plans*. *Update : Moving within same AX versions (For example moving from AX 2012 R2 CU 8 to AX 2012 R2 CU9) *Upgrade : Moving to higher AX version (For example...
Dynamics AX Sustained Engineering: Provide feedback on your AX 2012 R2 and R3 deployments Blog bot DAX Blogs 0 18.12.2015 13:11
emeadaxsupport: Form created in e.g. AX 2012 RTM or AX 2012 R2 with ManagedHost control on its design fails to open on AX 2012 R3 Blog bot DAX Blogs 0 21.09.2015 19:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
emeadaxsupport: Get started with AX 2012 R3! Blog bot DAX Blogs 0 05.05.2014 09:11
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
Часовой пояс GMT +3, время: 21:51.
