Старый 28.01.2016, 10:06   #6
spectr is offline
spectr
Аватар для spectr
287 / 70 (3) ++++
С SDK:
  • Updating an attribute using setValue will not cause the OnChange event handlers to run. If you want the OnChange event handlers to run you must use fireOnChange in addition to setValue.
  • When Microsoft Dynamics CRM for tablets is not connected to the server setValue will not work.
  • You cannot set the value of composite attributes. More information: Write scripts for composite attributes.
Порпробуй метод перевесить с лоада на сам onChange поля на форме
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 10.05.2014 06:30
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
Часовой пояс GMT +3, время: 06:06.
