я поменял на формах для больших таблиц и кое в чем мне это помогло.
If you are running on SQL Server, you must also be aware of a very specific performance problem that applies to forms: · Setting the SourceTablePlacement property to the default value (Saved) will often make opening forms that display data from tables that contain many records (1,000,000 or more), for example G/L entries, very slow. To fix this problem, set the SourceTablePlacement property to First in these forms. |
