Читал, вычитал вот это:
If your instance of SQL Server is installed on a computer that is running Windows 2000 Advanced Server, Windows 2000 Datacenter Edition, Windows Server 2003, or Windows NT, you can use the /3GB switch in the Boot.ini file on your computer. As a result, SQL Server 2000 can use up to 3 GB of available memory on your computer.
