Старый 05.10.2016, 15:11   #1
organicax: Basic sales order to invoice flow in AX7
Источник: https://organicax.com/2016/10/04/bas...e-flow-in-ax7/
If you have been working with AX for a while you will likely know the basic flow of a sales order. If you are new to AX it’s handy to see the basic process move through to invoice so you can conceptualize what needs to be done in the system. There are a lot of parameters and variables like how the item is configured, security aspects on how this process will be implemented etc. that you will need to consider to overlay on your processes.
Here is a quick overview.
AX7 Build 7.0.4230.16130
Cheers
Lachlan
Filed under: Sales and marketing
organicax: Stopped for sales order – default order settings Blog bot DAX Blogs 0 08.04.2016 02:19
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Sales Blog bot DAX Blogs 0 25.04.2012 03:18
Часовой пояс GMT +3, время: 22:08.
