Старый 08.10.2016, 19:11   #1
organicax: Clearing usage data in AX7
Источник: https://organicax.com/2016/10/08/cle...e-data-in-ax7/
When users are working in AX running reports, personalizing forms all these tweaks are kept in usage data. Sometimes it’s good to clear this out when you are getting a “funny” result on working with a form for example.
This data also becomes invalid if the underlying development object changes so you should be aware that while it is convenient it’s not permanent and usually needs to be cleared out when the system is updated.
If an individual user needs to clear their own usage data here is a quick overview.
AX7 Build 7.0.4230.16130
Cheers
Lachlan
Filed under: User tips
kurthatlevik: Master data concepts Blog bot DAX Blogs 0 18.02.2016 12:11
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Часовой пояс GMT +3, время: 03:39.
