Старый 02.11.2016, 14:11   #1
emeadaxsupport: Cannot see all users on the domain in Active Directory Import Wizard
Источник: https://blogs.msdn.microsoft.com/axs...import-wizard/
Issue: When you use a user to run the Active Directory Import Wizard in Microsoft Dynamics AX, you cannot see all users on the domain. This problem occurs if the user that you use is not domain administrator. Cause: This problem occurs because some settings on the network domain are required for non-domain administrators to... Read more
emeadaxsupport: Checking your MS Dynamics AX users against Active Directory domain resolution Blog bot DAX Blogs 0 02.10.2015 20:14
lcs: [Awareness and Resolved] Lifecycle Services Portal Users unable to authenticate with Azure Active Directory credentials - Thursday, August 27th 2015 Blog bot DAX Blogs 0 28.08.2015 06:11
Microsoft Dynamics CRM Team Blog: How to Synchronize CRM Online with your Active Directory Blog bot Dynamics CRM: Blogs 0 19.07.2013 02:17
emeadaxsupport: Error while importing a user group from the Active Directory into Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 22.05.2012 19:11
dax-lessons: Active directory in Axapta Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 13:10.
