organicax: Item cost default on movement journal
Источник: https://organicax.com/2016/11/05/ite...ement-journal/
============== In a previous post we had a look at the default cost used on the counting journal. If you are adjusting inventory or taking on inventory with the movement journal then the item cost will follow a similar defaulting approach. Here is a quick overview. AX2012 R3 CU11. Cheers Lachlan Filed under: General ledger, Product information management ![]() Источник: https://organicax.com/2016/11/05/ite...ement-journal/
