Старый 23.02.2017, 07:22   #1
vasantharivali: Auto comments on our customization codes by Editor Script Class
Источник: https://vasantharivali.wordpress.com...-script-class/
Hi Friends,
Here I have posted the code for auto comments by amending Editor Scripts class.
Adding auto script CODE comments
// Changes: XYZ to your intial name
public void addCommentsCODE(Editor _e)
int startLine = _e.selectionStartLine();
int endLine = _e.selectionEndLine();
str prefixCompany = “CONTOSO”;
str developerID;
str tagStart;
str tagEnd;
switch (curUserId())
case “vasan”: developerID = “Vasanth”;
break;
case “steve”: developerID = “Steven”;
break;
default:
developerID = “XYZ”;
tagStart = strFmt(“//–> %1 modified on %2 %3 by %4: %5 ~ mod description\n”,
enum2str(currentAOLayer()),
date2str(today(), 321, 2, 3, 3, 3, 4), time2str(timeNow(), 1, 1),
prefixCompany,
developerID
tagEnd = strfmt(“// scripts -> you find the method created. Hope it will help you.
// Vasanth Arivali
goshoom: Class extensions Blog bot DAX Blogs 0 18.07.2016 17:11
emeadaxsupport: How to assign an LTL Freight class code to an item using Nation Motor Freight Classification (NMFC) codes Blog bot DAX Blogs 0 25.03.2015 01:13
german_nav_developer: Dynamics NAV 2013 R2 multi-tenancy – Viele Mieterinnen ohne Stress und Neid Blog bot Dynamics CRM: Blogs 0 30.12.2013 19:00
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
german_nav_developer: Codepage und Multilinguale Dynamics NAV Installationen Blog bot Dynamics CRM: Blogs 0 05.06.2011 15:51
Часовой пояс GMT +3, время: 16:16.
