Старый 02.03.2017, 20:11   #1
Kashperuk Ivan: Extensible enums: Breaking change for .NET libraries that you need to be aware of
Источник: http://kashperuk.blogspot.com/2017/0...hange-for.html
A while back I wrote a blog post describing the Extensible Enums - a new feature that is part of Dynamics 365 for Operations: http://kashperuk.blogspot.com/2016/0...ible-base.html I explained that when marking an enumeration as extensible, the representation of this enum under the hood (in CLR) changes. Here's the specific quote: The extensible enums are represented in
baseenum, d365o, финансовая аналитика
Kashperuk Ivan: Development tools: Editor scripts in Microsoft Dynamics AX 7 or Visual Studio X++ code snippet library Blog bot DAX Blogs 0 27.09.2016 14:11
Kashperuk Ivan: Development tutorial: Extensible base enumerations in Microsoft Dynamics AX 7 Blog bot DAX Blogs 0 27.09.2016 00:19
stoneridgesoftware: Changes to Microsoft Dynamics NAV Change Log System: How to Revert its Behavior Blog bot NAV: Blogs 0 23.06.2016 20:13
Kashperuk Ivan: Buy MorphX IT in Russian Blog bot DAX Blogs 6 13.04.2007 17:48
Часовой пояс GMT +3, время: 17:38.
