dynamicsaxhints: Top overridden form methods in AX 2012 R3
Источник: http://dynamicsaxhints.blogspot.com/...n-ax-2012.html
============== Today I am going to analyse form and datasource methods in standard AX application and find the most and the least overridden. Form Overridden rate is calculated as the ratio of the number of forms, where a method is overridden, to the total number of forms. Not surprisingly, init method is almost always overridden. run, close and closeOk methods are often overridden. All other methods are rarely overridden. The following methods are never overridden in standard application: addHistory blockPersonalization closedCancel controlMethodOverloadObject copy getActiveWorkflowConfiguration getActiveWorkflowTrackingStatus getActiveWorkflowWorkItem initWorkflowControls loadUserSetting reload send setApply skipSaveUserSetting updateWorkflowControls Datasource Overridden rate is calculated as the ratio of the number of datasources, where a method is overridden, to the total number of datasources. Top overridden methods are: init, active, executeQuery, write, validateWrite, initValue, delete, linkActive, create. All other methods are rarely overridden. The following methods are never overridden in standard application: defaultMark findValue markAllLoadedRecords refreshEx Conclusion This standard application statistics reflects what is usually overridden by a developer on a regular project: - init, run, close methods on a form - init, active, executeQuery, write methods on a form datasource. Источник: http://dynamicsaxhints.blogspot.com/...n-ax-2012.html
И суть данного исследования заключается в ...?
| За это сообщение автора поблагодарили: 6a6kin (1), mazzy (2), sukhanchik (2). | |
Вань, ну человек, старался, работал - а ты такие вопросы задаешь...
| За это сообщение автора поблагодарили: mazzy (2). | |
...запретить оверлей метода init.
...ничего не делать с методом loadUserSetting. |
