Старый 06.07.2017, 11:06   #1
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Изменения в Table Browser в последнем Platform Update 8
Видели, что теперь администраторы не смогут данные править через обозреватель таблиц на live environments?
Table browser is now in read-only mode
The table browser form is now in read-only mode on runtime environments (Sandbox Tier-2 and Production).
The table browser form is designed for developers to quickly create and edit test data on development environments. It was also available to system administrators on runtime environments. As of Platform update 8, system administrators can only access the table browser in read-only mode on runtime environments, this is in reaction to live incidents caused by human error when system administrators inadvertently edited or removed live system data.
#синдромвахтера, change tracking
stoneridgesoftware: Microsoft has Released the 4th Platform Update for Dynamics 365 for Operations Blog bot DAX Blogs 0 12.04.2017 02:30
lcs: Issue with Update tile in Microsoft Dynamics 365 for Operations platform update 4 release on LCS Blog bot DAX Blogs 0 25.02.2017 02:19
vasantharivali: Enhanced SysTableBrowser – View only the fields you want in table browser Blog bot DAX Blogs 0 07.10.2016 15:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 13:13.
