Старый 08.10.2017, 18:55   #2
ax_mct is offline
ax_mct
2,548 / 1091 (0) ++++++++
Note that by definition that means only one of the ISV solutions can replace it. If two attempt to accept() the result, an error will be shown.
That would typically mean that a logical conflict exists between the two ISV solutions, and the VAR would need to decide which ones to use, or make it configurable somehow.
Интересно. Спасибо.
Я правильно понимаю что проверка конфликта решений ISV не на этапе компиляции, а как runtime error?
chain of command
Kashperuk Ivan: Development Tutorial: Extensibility: Adding a table display/edit method and showing it on a form in PU11 Blog bot DAX Blogs 2 09.10.2017 13:36
Kashperuk Ivan: Development Tutorial: Extensibility: Adding a table display/edit method and showing it on a form in PU10 Blog bot DAX Blogs 20 07.10.2017 12:42
Kashperuk Ivan: Development tutorial: SysExtension framework with SysExtensionIAttribute and an Instantiation strategy Blog bot DAX Blogs 0 01.04.2017 02:17
Kashperuk Ivan: Development tutorial link: Extensibility challenges: Pack/Unpack in RunBase classes Blog bot DAX Blogs 0 01.04.2017 02:17
Kashperuk Ivan: Development tutorial: SysExtension framework in factory methods where the constructor requires one or more arguments Blog bot DAX Blogs 4 19.03.2017 23:56
Часовой пояс GMT +3, время: 02:15.
