sinedax: Microsoft Dynamics 365 for Finance & Operations - Change the standard URL in a VHD Machine
Источник: http://sinedax.blogspot.com/2017/10/...r-finance.html
============== Hi All In a Business scenario, we can setup several VHD all-in-one box Environments in the same Datacenter for various purpose. One issue is the standard base URL that usually is https://usnconeboxax1aos.cloud.onebox.dynamics.com/ for all Envs. In order to change it and allow the team to reach the different Envs, for each Dev Box replace “usnconeboxax1aos” with the desired URL like “XXXXXXX”: 1- Modify Endpoint URL on IIS 2- Modify web.config files in the C:\AOSService\webrootand replace all standard “url name” entrieswith the new one (XXXXX) 3- Modify wif.services.config as per the previous step 4- Modify “Host” file on C:\Windows\System32\drivers\etc like that: 127.0.0.1 xxxxx.cloud.onebox.dynamics.com 5- Change the “hosts” file on C:\Windows\System32\drivers\etc in your Laptop, like:XX.XX.XX.XX xxxx.cloud.onebox.dynamics.com where XX.XX.XX.XX will be the IP of the VHD Box You have to add an entry for each VHD URL Env. 6- As the last step, make the Admin User Provisioning Till Soon! Источник: http://sinedax.blogspot.com/2017/10/...r-finance.html
