Старый 03.04.2018, 15:44   #18
ax_mct is offline
ax_mct
Banned
2,548 / 1091 (0) ++++++++
Прокрастинируя перед задачей которую неоценил раза в три, поинтересовался как у других.
Опять таки язык Apex. Хотелось бы чтобы MFP сравнивал с ним и другими, прежде чем заявлять что X++ самый самый. Особенно если речь о лидерах рынка за которыми идет гонка и которых в то же время как бы не существует.
https://developer.salesforce.com/pag...mming_Language
Apex Features and Functionality
In addition to the essential capabilities of running on demand in a multi-tenant environment, Apex Code brings a number of other features that greatly expand the power developers have in using the Force.com platform and in the range of applications they can build.
Apex Code and event model. Apex Code can be tied to the execution of the platform, enabling developers to exert fine-grain control over an application. When thinking about the Apex code, it’s useful to consider the analogy of stored procedures and triggers, since fundamentally the language is tied to behaviors on the data, as opposed to providing a higher level UI language or representation. Hence developers can tie Apex Code into almost every aspect of an application’s behavior: overriding the behavior in existing buttons, creating a new button, manipulating the control of a custom link, programming the control of an inline s-control, or even overriding the behaviors associated with a related list and data.
Consider an app that enables the user to create a new lead in Force.com by clicking the save button to commit that record to the database. With Apex code, developers can create and execute code residing on salesforce.com’s server to intercede just after the button is clicked. The code might check for any duplicate records, and if it finds any, implement a data quality scenario that notifies the user. Otherwise, the record commits to the database as is normally the case. (See Apex Code Example above.)
Transaction control. Because Apex Code is closely bound to Force.com data, developers can readily add transactional features to their applications. For example, if one user is referencing a field while somebody else is trying to delete it, the system is aware of the conflict. Apex Code also features data commits and rollbacks, which are especially important when working across multiple objects.
Packaging, re-use and Web services. Apex Code uses a packaging model similar to that of Java, in which reusable packages of code can be invoked from each other or from within triggers. Unlike Java, however, Apex is not object oriented in the sense that those packages can be modified through inheritance. Significantly, any method defined in a package can optionally be automatically exposed as a Web service, and thus can be invoked via the SOAP API or directly through the AJAX toolkit.
Performance, scalability and upgrades. Because Apex Code runs on demand, scalability, compatibility and maintenance issues are salesforce.com’s responsibility, not yours. Apex-developed applications can scale indefinitely to support additional users, without your having to deploy additional servers. Applications potentially run faster because a single query can obtain information from multiple objects.
When newer versions of Force.com and the Apex code itself are introduced, your code is never rendered obsolete. Force.com ensures backward compatibility by maintaining processor-specific versions of Apex virtual machines, which in turn correspond to the API. As a result, your code continues to operate without modification.
Apex Code and the AppExchange. Apex Code can be packaged along side custom objects, S-controls and other platform features, allowing developers to redistribute their Apex Code-enhanced apps via the same AppExchange directory available today.
ax8, dyn365fo, extensions, mfp
mfp: Extensible X++ – Method signatures Blog bot DAX Blogs 0 31.08.2017 18:11
mfp: Extensible Inventory Dimensions Blog bot DAX Blogs 0 10.08.2017 14:11
german_nav_developer: Dynamics NAV 2013 R2 multi-tenancy – Viele Mieterinnen ohne Stress und Neid Blog bot Dynamics CRM: Blogs 0 30.12.2013 19:00
german_nav_developer: Codepage und Multilinguale Dynamics NAV Installationen Blog bot Dynamics CRM: Blogs 0 05.06.2011 15:51
mfp: X++ - A mananged language Blog bot DAX Blogs 1 20.01.2011 00:51
Часовой пояс GMT +3, время: 04:21.
