Старый 11.09.2018, 18:11   #1
dynamicsaxinsight: D365FO: Data entity filter on enum field
Источник: https://dynamicsaxinsight.wordpress....on-enum-field/
To filter data entity using an enum field, we need to use a specific query expression syntax. For example, to filter Purchase order header data entity, PurchaseOrderHeadersV2, to get only ‘Confirmed’ purchase orders, we can add filter to DocumentApprovalStatus entity field which sources its value from VersioningDocumentState enum like below:
https://usnconeboxax1aos.cloud.onebo...ApprovalStatus eq Microsoft.Dynamics.DataEntities.VersioningDocumentState’Confirmed’
As you can see below the query filter successfully filters Purchase order header entity to get only ‘Confirmed’ purchase orders:
atinkerersnotebook: Configuring a BYODB and Creating a Full and Incremental Entity Export Blog bot DAX Blogs 0 25.05.2018 15:11
dennis365foroperations: Yes, it’s here! The Copy configurations feature (and a look at other improvements related to Data Management) Blog bot DAX Blogs 0 12.10.2017 16:11
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 02:15.
