Старый 01.11.2018, 03:14   #1
25,643 / 848 (80) +++++++
yetanotherdynamicsaxblog: Upgrade from 7.x to 8.+ series | Post 2 | Deploy Dev and Grab source DB
Источник: http://yetanotherdynamicsaxblog.blog...es-post-2.html
Introduction
In these series of posts. I will try to run you through the process of how you can complete the upgrade from 7.x to 8.+ of Dynamics 365 for Finance and Operations.
Quick navigation:
Upgrade from 7.x to 8.+ series | Post 1 | Start in LCS
Upgrade from 7.x to 8.+ series | Post 2 | Deploy Dev and Grab source DB (you are here)
Upgrade from 7.x to 8.+ series | Post 3 | Validate Code and Data in Dev
Upgrade from 7.x to 8.+ series | Post 4 | Setup a new Build
Upgrade from 7.x to 8.+ series | Post 4 | Upgrade Sandbox and finally Production
Deploy 8.x environments
You will need to deploy new environments. There is no "in-place" upgrade of your existing environments. The new environments will be on the version you are upgrading to. Fortunately, deploying new environments is easy to do through Lifecycle Services (LCS). You will need a decent Development VM to connect to the upgraded metadata, and check the code for any issues.
I typically go for a DS13v2 which has local SSD. I normally give it 14 disks of size 48GB, which will all be striped for maximum throughput. This has served me well so far. I don't chose premium storage, but go for standard storage. There are probably lots of preference out there, and I'm more than willing to learn from the community what they recommend.
Make sure the VM is hosted on your own (or customers) Azure Subscription. This way you are guaranteed to get local admin user. Also make sure the topology is Development. Pick an empty database, as you won't need that Contoso data for what we're about to do.
Prepare Database
While the Development VM is deploying, here's another neat thing you can do, if you haven't already done so. Setup a cloud Storage Account in the Azure Subscription. It can be a cheap Standard Storage (general purpose v2) type, with only Local Redundancy, on a Cold Tier - nothing fancy. Create yourself a blob storage where you can put the database which you will get from your source environment. If you haven't done this in Azure Portal before, let this be your first time. Things to consider; the Storage Account name must be unique (for that specific Azure Region). But you're a good citizen, and always used a good naming practice, right?
You will need three things from this cloud storage:
  1. The Storage Account Name
  2. The name of the blob storage
  3. The Access Key (which is found on the Azure Blade - look for the yellow key icon).
When you have the storage account ready, I bet the deploying of the Development VM is still spinning, so let's prepare a backup of the source database. We will use it to validate the upgrade. This is just a test, to make sure the upgrade experience will be smooth.
Head over to your Sandbox (Tier2) AOS, and extract the database from there. If you want to test on a fresh copy from Production, you will have to get Microsoft to do a Database Refresh first. But let's assume the one on the Sandbox is fresh enough.
The possibly quickest and easiest way to get the database extracted, at the point of writing, and while we are waiting on Microsoft to get the tooling in place in LCS, is to use the community driven D365FO.tools PowerShell Library.
Install the library on the AOS server using the following command. You'll have to click "Yes" and "Yes to all" on any questions.
Install-Module d365fo.tools
Then run the following to extract the database. It basically prepares a bacpac with the "_adhoc"-suffix, and saves it do the D-drive.
Import-Module d365fo.tools
$dbsettings = Get-D365DatabaseAccess
$baseParams = @{
DatabaseServer = $dbsettings.DbServer
SqlUser = 'sqladmin'
SqlPwd = 'SQLADMIN_PASSWORD_FROM_LCS'
Verbose = $true
$params = $baseParams + @{
ExportModeTier2 = $true
DatabaseName = $dbsettings.Database
NewDatabaseName = $($dbsettings.Database + '_adhoc')
BacpacFile = 'D:\Backup\sandbox_adhoc.bacpac'
Remove-D365Database @baseParams -DatabaseName $($params.NewDatabaseName)
New-D365Bacpac @params
Then using the cloud storage you've hopefully prepared, lets upload the bacpac to the cloud. We will later download it to the development VM.
$params = @{
AccountID = 'STORAGE_ACCOUNT_NAME'
AccessToken = 'LONG_AND_SECRET_ACCESS_KEY_FOUND_ON_THE_STORAGE_ACCOUNT_IN_THE_AZURE_PORTAL'
Blobname = 'NAME_OF_THE_BLOB'
FilePath = 'D:\Backup\sandbox_adhoc.bacpac'
DeleteOnUpload = $false
Invoke-D365AzureStorageUpload @params
The database extract in form of a bacpac now awaits in the cloud storage, and when the development VM is ready, you can use the same PowerShell Library to download it and install it on your development VM.
But first, you need to make sure the application actually builds. I will address that in the next post.
За это сообщение автора поблагодарили: gl00mie (2).
yetanotherdynamicsaxblog: Upgrade from 7.x to 8.+ series | Post 5 | Upgrade Sandbox and finally Production Blog bot DAX Blogs 0 01.11.2018 03:14
yetanotherdynamicsaxblog: Upgrade from 7.x to 8.+ series | Post 4 | Setup a new Build Blog bot DAX Blogs 0 01.11.2018 03:14
yetanotherdynamicsaxblog: Upgrade from 7.x to 8.+ series | Post 3 | Validate Code and Data in Dev Blog bot DAX Blogs 0 01.11.2018 03:14
yetanotherdynamicsaxblog: PowerShell script for synchronizing the database Blog bot DAX Blogs 0 28.01.2018 22:12
survivingcrm: From AppSource to Solutions to Dynamics 365 Apps Blog bot Dynamics CRM: Blogs 0 14.01.2018 19:16
Часовой пояс GMT +3, время: 01:03.
