Старый 13.11.2018, 11:49   #3
Pokersky09 is offline
Pokersky09
Тянем из TFS
Вариант с получением из TFS последнего актуального задания.
Нужно добавить также Refrences:
C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\CommonExtensions\Microsoft\TeamFoundation\Team Explorer\Microsoft.TeamFoundation.WorkItemTracking.Client.dll
C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\CommonExtensions\Microsoft\TeamFoundation\Team Explorer\Microsoft.TeamFoundation.Client.dll
Также заменить:
DevProject.visualstudio.com
User111
Код:
using EnvDTE;
using EnvDTE80;
using System;
using Microsoft.TeamFoundation.WorkItemTracking.Client;
using Microsoft.TeamFoundation.Client;
public class C : VisualCommanderExt.ICommand
    public String  getCurText()
        Uri collectionUri = new Uri("https://DevProject.visualstudio.com");
        TfsTeamProjectCollection tpc = new TfsTeamProjectCollection(collectionUri);
        WorkItemStore workItemStore = tpc.GetService<WorkItemStore>();
        string query =
                "select [System.Title] " +
                " from " +
                " WorkItems " +
                " where [System.WorkItemType] <> '' " +
                " and [System.State] <> 'Closed' " +
                " and [System.State] <> 'Removed' " +
                " and [System.AssignedTo] = '" + workItemStore.UserIdentityName + "' " +
                " order by [Changed Date] desc";
        WorkItemCollection queryResults = workItemStore.Query(query);
        foreach (WorkItem workItem in queryResults)
            return workItem.Title.ToString();
        return "";
    public void Run(EnvDTE80.DTE2 DTE, Microsoft.VisualStudio.Shell.Package package)
        EnvDTE.TextSelection ts = DTE.ActiveDocument.Selection as EnvDTE.TextSelection;
        System.String s = "// " + this.getCurText() + ", User111 " + System.DateTime.Now.ToString("dd.MM.yyyy");
        int StartLine = ts.TopLine;
        int EndLine = ts.BottomLine;
        if (ts.Text != "")
            ts.GotoLine(StartLine);
            ts.StartOfLine((EnvDTE.vsStartOfLineOptions)(1));
            ts.Insert(s + " -->");
            ts.NewLine(1);
            ts.GotoLine(EndLine);
            ts.EndOfLine();
            ts.NewLine(1);
            ts.Insert(s + " <--");
        else
            ts.GotoLine(1);
            ts.NewLine(1);
            ts.EndOfLine();
            ts.GotoLine(1);
            ts.Insert(s);
ax7, editor script, полезное
mfp: X++ in AX7: String truncation Blog bot DAX Blogs 6 29.05.2020 18:24
mfp: X++ in AX7: Garbage Collection Blog bot DAX Blogs 0 21.12.2015 11:11
mfp: X++ in AX7: Method signatures Blog bot DAX Blogs 0 19.12.2015 16:12
mfp: X++ in AX7: Const keyword Blog bot DAX Blogs 0 17.12.2015 12:02
mfp: X++ in AX7 Blog bot DAX Blogs 0 02.12.2015 22:13
Часовой пояс GMT +3, время: 10:20.
