Старый 10.12.2018, 04:50   #1
ievgensaxblog: MSDyn365FO. Code to build cross reference data without a full compile.
Источник: https://ievgensaxblog.wordpress.com/...-full-compile/
After 8.1 there is no need to do code upgrade and build standard code supplied by Microsoft or at least we’ve been told so. However, it’s impossible to refresh cross references without building model with Visual Studio tools and we need this because now hotfixes and monthly updates are cumulative and include binaries and X++ code as well, so cross reference data on dev VMs becomes outdated quite quickly.
While MS is working on actual solution, I dug a bit into xppc that compiles X++ code and build cross references and here you are, this code can be used to build cross references for a module without compile, that is way faster!
using Microsoft.Dynamics.AX.Framework.Xlnt.XReference;using Microsoft.Dynamics.AX.Metadata.XppCompiler;using System;class XRefBuilder{ static void Main(string[] args) { try { string moduleName = "ApplicationCommon"; string metaDataPath = @"K:\AosService\PackagesLocalDirectory"; ICrossReferenceProvider xRefProvider = CrossReferenceProviderFactory.CreateSqlCrossReferenceBatchProvider(".", "DYNAMICSXREFDB", moduleName, true, true, new DiagnosticsHandler()); xRefProvider.StartBatch(); new MetadataXRefSweeper( metaDataPath, moduleName, xRefProvider, DateTime.MinValue, new DiagnosticsHandler()).Run(); xRefProvider.CommitBatch(); } catch (AggregateException ae) { ae.Handle(ex => { Console.WriteLine(ex.InnerException != null ? ex.InnerException.Message : ex.Message); return true; }); } }}Note catch section, it was a big surprise for me, but standard code has lots of compile issues, for example, KanbanMultiDelete action menu item has EnumParameter property populated but EnumTypeParameter is not. In 2012 days it was not possible to do this, but now you can literally type anything into EnumParameter without specifying enum and save it. Cross reference builder would try to find that enum and throw an exception saying that cannot find an enum with empty name. That’s why I have that catch section and that’s what xppc does, just skip all these errors and probably log them somewhere.
Another gotcha here is OutOfMemoryException that you can get with ApplicationSuite model, so don’t forget to handle it as well.
Старый 10.12.2018, 13:46   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
А почему нельзя просто compile запустить? он же в пределах часа по всему работает. или они планируют compile убрать?
Старый 10.12.2018, 21:13   #3
skuull is offline
skuull
700 / 752 (27) +++++++
Так раза в 3 быстрее.
Старый 12.12.2018, 12:19   #4
skuull is offline
skuull
Сообщение от skuull Посмотреть сообщение
А почему ? Потому что не строит перекрестные ссылки по коду, только по метаданным
Старый 12.12.2018, 12:36   #5
trud is offline
trud
Записей в блоге: 1
Надо в пост картинку добавить
ievgensaxblog: Advanced cross-reference search. Blog bot DAX Blogs 0 26.11.2017 05:38
patrickmouwen: 1yr with AX7 Data Management – My top 12 learnings Blog bot DAX Blogs 2 12.10.2016 15:14
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
wiki.dynamicsbook: Changes Made in Navision Attain 3.01B Blog bot Dynamics CRM: Blogs 0 21.08.2008 20:43
Часовой пояс GMT +3, время: 22:18.
