Kashperuk Ivan: [Heads up] Explicit dependency required for enabling Process Guide based flows in Warehouse Mobile App
Источник: http://kashperuk.blogspot.com/2019/0...-required.html
============== Introduction With release of version 8.1.3 (build numbers going as 8.1.227.xxxx), we introduced an additional configuration option on the Mobile device menu items, which controls whether or not the system will attempt using the Process Guide framework for executing a mobile flow This is a temporary configuration option, and is supposed to serve two purposes: Allow having a partially Источник: http://kashperuk.blogspot.com/2019/0...-required.html
